Programing Torque Compensation
It can be done but the results won't be exactly equivalent. The programmed in control responses will be proportional to the square of the airspeed but the thrust off set effects are proportional to the square of the RPM. In a full throttle climb the airspeed will be quite a bit lower than level flight at the same RPM, for example.
