RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 05-06-2007 | 08:24 PM
  #5943
Zippi's Avatar
Zippi
My Feedback: (10)
Default RE: U-Can-Do 3d 46?
Jetdrvr393,
I had a Saito 82 on a Bad Boy 2 with an APC 14 X 4W prop and it would shake really bad at low rpms until you lean the low end out. I think it was around 1/2 turn open. I just bought another Satio 82 thats going on a VOIS 4D plane and I'll be using the same prop. Very good running engines once you get them set properly. If the low end being to rich is not your problem then you may want to balance your prop again.
