Changing a 2ch radio to use for 1/2 A plane
BMatthews-
I didn't catch what you said about the servo connection at first then I reread your post. You had it right. It was a kick to see everything work with the other battery and switch harness connected. The ESC is as large as the receiver, and I don't need it.
It sure is great to be able to find out what will work on this forum.
Thanks again- Lynn
