RE: Engine problem
If you were running it rich, there may be fuel spray coming from your carb, making appear as fuel was coming from the head. Run it again and take a piece of card board and hold it between the carb and the cylinder. If it gets wet, then you know the answer! Second, make sure your muffler is tight and is sealed against the exhaust.
Hope that helps!
