RCU Forums - View Single Post - SERVO MOVES
Thread: SERVO MOVES
Old 05-07-2007 | 07:42 AM
bruce88123
Default RE: SERVO MOVES
Make sure there is NO covering in the way anywhere around the elevator but especially near the hinges. You'd be surprised how little it takes. Make sure the previously cut off hinges are not sticking out and rubbing. Then tighten down the servo a little more and go fly it as long as the elevator actually moves through the desired range. Check the battery before EVERY flight, something you should do anyway.
