RE: Saito 125 Fuel Mix
Ditto on the Castor oil. I always make sure there is some in the fuel mix. The higher Nitro content may make the engine idle better but they should run just fine on the mix you have. Dispite what some magazine engine authors say, Castor is good for your engine, good protection for lean runs and good protection for your bearings.
Cheers,
Chip
