RE: GP Cap 232 40 Size Build Modifications.
DUAL ELEVATOR SERVOS MODIFICATION
Installing the dual elevator servos are a simple task using this mini-servos, on the fuselage sides, right at the elevator push rods exits I drew what is was to be the servo bay, I took care on the alignment using this push rod exit as a guide, then used the dremel tool to make the bay, then sanded to fit ok.
Photos speak for their self.
Push rods will be installed after covering.
