RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 05-07-2007 | 01:32 PM
  #1245
aero nut
Default RE: gas fuel with glo plug no ignition
Hi Bob!
Well finally decided to run the MAGNUM 1.80 on gas/glow with 10% oil with is normal glow carb
It ran very well but the setting point was very sensitive, the other thing I've noticed was that it ran hotter tan with glow, do you have any idea? maybe more oil, my buddy is making an adapting plate for a walbro carb then I can try it again and see hot it works, it ran very good but if you go over just a nick on the needle valve it will stop (overheat). any input.
Thanks.
Your Buddy down in Baja.
Aero Nut.
