RE: wrinkle in coating
Best answer I can give you:
the blow dryer blows too much air compared with its heat. A heat gun allows you to apply heat in a more controlled manner without all the......uhhhhh.......hot air??????
This is basically the reason the hair dryer is ineffective. Both the heat gun and the hair dryer are typically in the 1000-2000 watt range. And both will reach temperatures above 200C.
