HELP! What's wrong??
I would suggest that you check the wire leads from the charger on the Tx side and the connector to the Tx pack. If these check out OK then I would suspect that the charger is toast. Take it apart and have a look - can't do much harm. Probably not worth sending it in to be fixed.
Ross
