T8uaps Programming Setup Help
I have a glider that has 4 servos in the wing.
2 for flaps and 2 for ailerons.
Type is set at GLD2FLP ...
alierons are in channels 1 & 7, flap servos ch.5 & ch.6
Alierons function normal ... Flaps are in full down position ...
Question: How do I set up my radio to use the flaps only?
is it possible to have a switch to turn them on then use the throtle lever to control amount of throw ...
or is this only controlled by the channel 6 knob.
The manual is not real clear on this ... I wanted to also have the option to crow my bird.
Would I have less headaches by just using a "Y" connector and use ch.6 for the flaps and change type to GLD1FLP?
Why is the manual so confusing?
or am I just dumb when it comes to programming this radio?
both flap servos work ... and I have flap trim when adjusting ch. 6 knob ... but it only makes the one side more or less than the other. I can not figure out how to raise or lower them together at the same time.
Please advise me of my dumbness ....
