RCU Forums - View Single Post - Alloy Dampers and the Savage X
Old 05-08-2007 | 10:02 AM
JMAPUK
Default Alloy Dampers and the Savage X
Can anyone help I am in the Uk and have just brought a savage X, I have recently upgraded a few part one of which where Purple Dampers GPM (shocks) lower and upper arms. The problem I have with these upgrade is i do not seem to be able to install the lower part of the shock to the lower part of the lower arm it just doesn't fit the ball joint which allows for some play on the shock is way to wide to fit into the slot on the lower arm, is there anything that i am missing to insert this damper(shock)
Regards
JMAP
