hi all,
i'm trying to decide on a elev. hookup for a Su-31 69" span.
a) 2 servos at the tail (short linkage)
b) 1 stronger servo at the mid section & a splitter (one push-rod going to the tail for each elev. half)
the weight in the tail is NOT an issue since i am moving the rudder servo upfront (pull-pull) and the smoke hookup using a separate battery & ST 2300 engine will provide enough ballast up front
the only issue is to have independent elevator control (possible mix) OR a hidden servo with a splitter for a more scale look
I would love some feedback,
thanks, Vasek
