RE: how much shim to change down thrust?
Thanks for the info guys. [8D] I can't change the incidence because the wing (s) is pinned into the fuse when it's mounted each time. I'll give the shimming a try tomorrow when I go fly. I just didn't know where to start as far as thickness and I didn't want to be adding too much and loose control of the plane.
