RCU Forums - View Single Post - Solution for vertical edf take off!!??
Old 05-08-2007 | 10:12 PM
jongscx
Default RE: Solution for vertical edf take off!!??
Granted, if you were flying in perfectly still air, with a perfectly balanced aircraft, you could do it with one fan... but reasonably... and on a budget (a tight one) probobly not..
How much would the equipment be for servos, microcontroller, and gyro, if one were try this... not even including Rx, batts, airframe, etc... but just the equipment needed to get it hovering level...
