RCU Forums - View Single Post - World Models Spot-On 120
Old 05-08-2007 | 11:33 PM
riot3d
Default World Models Spot-On 120
Ever since I sold the Groovy 90 3A to a fellow club member after my initial test flight, I had been contemplating on getting another one for a more thorough testing. However, after a short discussion with my good friend Fai Chan - one of the owners of World/ Airborne Models - he convinced me to try one of their latest pattern offering - the Spot-On 120. The plane came in two different sizes, the 50 and the 120 size which retailed for $399.99. However, if you are a current NSRCA member, Fai will extend a 10% discount to you. Since I have a refurbished YS 140L sitting on the shelf, the 120 was an easy decision.
The construction of the Spot-On is almost identical to the Groovy - an all wood design with most of the surfaces including the trim pieces covered with World's very own "ToughLon" coverings, including the belly pan. The exceptions are the top cowling and the bottom chin cowl, which were both painted. I was having some problem on the Groovy with the trim pieces peeling off before assembly, but found the Spot-On a much better finishing.
Similar to the Groovy, the Spot-On came well equipped with the following accessories - spinner, fuel tank, aluminum stab/ adjuster tubes, carbon fiber gear, wheel pants and wheels, push rods for all moving surfaces, horns, clevises, an assortment of screws and their very own anti-vibration engine mount. The wing is a one piece design, therefore, no wing tube required.
Since I have had prior experience on building the Zen III and the Groovy 90 3A, I think the Spot-On 120 will be finished in no time. Of course, procrastination is always a big obstacle. Stay tuned ...
Adrian
ID:	680630   Click image for larger version
ID:	680631   Click image for larger version
