RE: wich to chose
The entire drivetrain, every moving part from the clutch bell to the wheel hexes will need to be upgraded. I'll try to list for you, pipe in anyone if I forgot something...
Clutch bell, spur gear, transmission output drivecups, driveshafts, differential spurs, spider gears, differential cases, diff covers would be a good idea too, diff outdrives, front and rear axles (dogbones), wheel hexes. You probably don't need to do all of this at the same time, start with a few and see how the rest hold up, replace them as you destroy them would be my plan.
