RCU Forums - View Single Post - Glo plug connector
Old 05-09-2007 | 08:50 AM
Rodney
Default RE: Glo plug connector
DelRay, I often do just what you do as it gives a much shorter profile than the commercial units does. You do have to make sure you get a brass wheel collar though as most are now aluminum and you can not solder to them. I just use a small piece of silicon fuel line as an insulator although lexon is probably a more permanent solution.
