RCU Forums - View Single Post - ys 110 equals what e-power
Old 05-09-2007 | 10:33 AM
dreadnaut's Avatar
dreadnaut
Default RE: ys 110 equals what e-power
ORIGINAL: woodie
ORIGINAL: dreadnaut
ORIGINAL: woodie
I have a flying friend using the AXI 4130 in a Venus II and 4200 mah 6S setup. Handles the Intermediate pattern easily.
Woodie
Woodie,
Would you hapen to know what his all up weight is? I am planing to scratch build and want to plan accordingly.
Dave
I think he is slightly over 9 lbs, will check with him and if different, I will post here.
Woodie
Thanks, I think I can get a 66'' span plane in at under 9lb. These ARFs tend to use heavier wood than I would, and heavier layups for the FG parts too. I have a set of plans for the Gator Giles that I have reverse engineered, and input into a CAD file. The wings will have double taper, but I like the way Mr. Chidgey designed the fuse. Simple and easy to build straight.
