RE: Neutralizing servos?
I think what they are saying is to power up the servo so it will center. Then make your arm 90degrees to the control surface. If the arm is a 1/2 spline off then use the sub trim in your TX ,if it has that feature,to get it set right. This should be done on any plane
David
