RE: ready to give up!!!
If the engine is not fully broken in, the engine will be hard to turn over because of the tight tolerences between the sleeve and the piston. Can you please post a pic. You said the there is a chip on the crankshaft, if there is a chip then a small piece of metal could be binding your engine. Not exactly sure on where you are saying that the chip is.
