RCU Forums - View Single Post - volt meter
Thread: volt meter
Old 05-09-2007 | 04:51 PM
MikeL
Default RE: volt meter
ORIGINAL: opjose
There was a great article about servos in FlyRC last month which talks about servo draw, etc. The variance between running the servos statically but mounted on the plane with linkages, etc., versus in the air was not that great enough to have a highly significant impact.
I wouldn't trust that article, then, either. Here's some contradictory evidence: http://www.centralhobbies.com/Engine...s/hydetxt.html If you want to experiment yourself, set up a test. It's not hard to do. Move four or so servos around without a real load on them, then move them around after hanging weights on the servo arms. Time out the difference. A servo simply works harder when it has to use greater force to attain or maintain a position. Hence, the advice you gave about calculating run times by moving the servos around without any appreciable load on them really isn't very good advice.
