RCU Forums - View Single Post - World Models Spot-On 120
Old 05-09-2007 | 05:19 PM
riot3d
Default RE: World Models Spot-On 120
ORIGINAL: woodie
ORIGINAL: tande
The wing is a one piece design, therefore, no wing tube required.
Adrian, if I may---"Airbone Models" on their web/site says "Plug-in rib wings" & a phone call confirmed this (two-piece wing with tube mt.)---can you clear this up please?---
Ed
Ed, if you examine the pictures Adrian posted in first message here, it shows a fuselage with the wing saddle showing as well as the 2 wing halves which I assume need to be joined at the center section. Looks like it ends up being a one piece wing after assembly.
Woodie
Wow Woodie, You're the man.
That's right. It has a wing joiner, and you need to glue the two wing halves together to make it a one piece wing. See pix below:-
ID:	680950   Click image for larger version
ID:	680951   Click image for larger version
ID:	680952   Click image for larger version
ID:	680953   Click image for larger version
