RCU Forums - View Single Post - Predator UAV
Thread: Predator UAV
Old 05-09-2007 | 05:20 PM
jollyroger
Default Predator UAV
I just bought this plane at Toledo and although the plane appears to be well built, I find the construction manual to be very lacking in details. There is no instruction for running the aileron servo wires into the fuselage, as to where to cut the holes or how large, nothing. There was also no instruction dealing with the attachment of thge rear cowl, although having mounted a few I easily handeled this one. Also what servos do you recommend for the ailerons? I planned to use 2 GWS nano servos but they are much taller than the wing is deep.
It seems that you folks could have the designer change the wing to fuse attachment. I suggest making part of the fuse and the wings as one piece which can then be atached to the rest of the fuse with dowl and wing hold down screws, thus making the plane much easier to transport..
All in all it looks like it will be a fun plane to fly and may even try a camera system.
cheers Jollyroger
