RCU Forums - View Single Post - volt meter
Thread: volt meter
Old 05-09-2007 | 07:57 PM
opjose's Avatar
opjose
Default RE: volt meter
ORIGINAL: P-40 DRIVER
KC31406, to answer your question, Generally you would not want to fly if your flight pack go's below 4.8 volts using a loaded meter such as the one you pictured.
Which is a good answer to the original question.
Effectively, when in doubt, test. That will give you more accuracy than anything else.
