RE: E-Flite cessna?
It has some problems. Mine the struts were not the correct length and I had to redo those and it will tip stall if you slow it down too much on landing. I would put the elevator on low rates and do not hold much up elevator when landing or you will cause it to stall. On the first flight climb to altitude and check out the slow flight and you will not have any surprises when it gets close to the ground. I like mine. Oh, you may want to take the wheel pants off. They cause more problems than they solve.
Larry
