RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 05-09-2007 | 10:47 PM
  #2747
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: Wheeeeeeee.......... Blade CP!
Just took those pics......... that is swash all the way down and tamed down quite a bit. Using the flat woodies for the moment, can't seem to get my syms to balance out right. here is the right way to set up the HDX head. [link=http://www.helifreaks.com/viewtopic.php?t=17482]Finless's HDX build thread[/link]
Also rayellejay, I am using a Futaba 6EXH TX with my blade so I reversed the pitch in the radio. If you are using the stock setup, You have to Manually reverse the pitch by flipping the mixers and washout arms, ect. PITA if you ask me, I would just get 3 Hitec 55's and install them, they run oppisite of the S75's....... And ty men. I am far from a expert on CNC........ just have a little more tear down time involved with this setup, when it flys and all is good....its really good, when it's off........its still ok.....heh
Barrrick.................. will miss ya man, loved your havoc pics...we have two going nitely and have found the downwash from one will knock the other out of the air...........wheeeeeeeeeee....havoc wars!!!
ORIGINAL: rayelljay
The Eng;ishman 'ere.......
Can I throw out a question.....?
If the reason for going to a DD tail is primarily motor life and motors fail 'cos of brushes.....would there be any problem about going brushless in the tail.....?
I'm back to stock in the tail but I did order a CNC dual motor mount this A.M. so I'll give that a try.
I have the mH head set up ready to go but the 3DX-300 V2 cnc head is giving me fits around the pitch control links...got some cogitating to do....Arrow...you have any closups of your rig you wouldn't mind sharing.....?
I work with geometry all and every day in my work and I know there's an optimum condition....just can't quite get there.
I'm reasonably knowledgeable 'bout most things but heli heads ain't one of them. The standard bell-hiller upfit for the CP is symmetrical about the pivot point of the links....the mH head has links that are not symmetrical and they are straight but the other head introduces an angle into the link and that's what's getting me.....'tis there for a purpose I'm not recognizing.
Is there a head guru out there to set me on the path to enlightenment.....?
__________________________________________________ ______________________________________
Of all the things I ever lost............................................. I miss my mind the most!
ID:	681200   Click image for larger version
ID:	681201   Click image for larger version
ID:	681202   Click image for larger version
ID:	681203   Click image for larger version
