RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 05-09-2007 | 10:47 PM
  #2748
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Choppersrule Here:
Direct Drive vs Dual Drive:
Hmmmm, several of the members have not been satisfied with the Direct Drive configuation due to motors over heating,, Myself included. I mentioned that I was going to try the Dual Motor Set UP. Well, I did that tonight, took about 45 minutes and 3 BEERS.
Being an old guy, knowing that I'll never go 3D, the Dual Motor rocks.. As far as response, it's between a stock single motor and a Direct Drive motor. (I've done all of 'em) Much more stable than a singe motor. In the Dual Motor configuration, the motors share the load, and run very quite and very cool. You do have to re-adjust the proportinal gain and gyro gain, after installation.
If you decide to go with Dual Motors, the first flight or so, will be much different.. Take the first 2 flights slow..
Here's some pictures of my installation, maybe more than you want to see, but, it may help some Noobies.
Dave / Choppersrule
ID:	681205   Click image for larger version
ID:	681206   Click image for larger version
ID:	681207   Click image for larger version
ID:	681208   Click image for larger version
ID:	681209   Click image for larger version
ID:	681210   Click image for larger version
ID:	681211   Click image for larger version
ID:	681213   Click image for larger version
