RE: Unanswered emails?
Largely this is up to you. You should try to work things out yourself if possible.
However here is a hint.... and pretty much outlines what I would be doing ( or just might go ahead and do ) with this plane.
The specs call for a 500watt motor which sounds about right for very good performance.
I put a BP Hobbies 2915 5D, motor in my similiarly sized and weighted Super Sportster EP, with a Tower Pro 60A ESC ( from NP ) and two 2200 mAh LiPo batteries ( also from NP ) in a 3S2P configuration to produce 4400mAh.
I have been EXTREMELY happy with the performance of this .30 equivalent. The plane is a rocket and will fly for just shy of 30 minutes ( !!!! ) on a charge.
BTW: I purchased 4 more battery packs ( again from Nitroplanes) so that I can fly it for a solid hour and a half without recharging, with battery changeouts every 30 minutes.
In NP's stable [link=http://www.nitroplanes.com/c3exoubrmo11.html]THIS MOTOR ( CLICK ME! )[/link] would be about the same.
You would either have to wire up your own deans connector cable to produce the 3S2P configuration or you could purchase one already made from other vendors.
For maximum longevity and good speed I used a 9x6E prop, but for slightly shorter run times but far more vertical/hovering power I use an 11x7E prop.
Remember with electrics, the PROP determines how much power your electronics draw.
If you over prop, you run the risk of damaging the electronics, as the prop will demand more energy than the electronics can handle.
Underpropping results in longer flight times.
