RCU Forums - View Single Post - Fromeco regulator/ battery
Old 05-10-2007 | 02:42 PM
turbine50's Avatar
turbine50
Default RE: Fromeco regulator/ battery
Thanks for the info, that makes sense. I will be using 1 mini for throttle, 2 HS-645MG's for ail, 2 HS-5645MG's for ele, and one HS-5985 for rud. Todd from wacohobbystop.com says a 2600mah relion will be sufficient for that load. I've been looking around and found Airwild Pilot Shop has the Super Regulated Reliaswitch with pin flag and JR leads for $47.50. I figure those two will do the trick for this "smaller" airplane. This regulator/switch must be pretty new because not many in the buisiness I've talked to have heard of it...
[link=http://www.airwildpilotshop.com/MoreInfo-1.asp?title=product&id=441]Super Regulated Reliaswitch[/link]
