RE: dx6 and G3.5
I just got it to work the other day. You need to have it set up with the CCPM mode OFF! You will also need to run the trainer cable through the included G3.5 transmitter and select the 6 Channel Transmitter mode under the joystick selection. You need to play with the channel mapping to get everything going smooth but it helps to learn the settings on the TX without crashing your heli, which helped me out a lot since this was my first TX of this kind!
