RCU Forums - View Single Post - Savage X Diff Housing Conversion...What Parts?
Old 05-11-2007 | 12:21 AM
takenotes Bch's Avatar
takenotes Bch
Default RE: Savage X Diff Housing Conversion...What Parts?
Thought u guys might be interested to know
ashburg.the stock x ss cases were shimmed WRONG from the factory LOL. They had the shims up against the diff cups, not where they would fix any slop in the crown gear/pinion mesh.I thought they did shim the housings (like they should!) from the factory, but they don't...they only put washer shims on the cups between the cups and the bearings.
The shims need to be between the bearing and the housing - moving the ring gear tight onto the pinion gear
This is evidently why the savage has so many pinion breakage problems (if it hasn't broken, bash on it harder and it will)
[sm=lol.gif]
