RCU Forums - View Single Post - Night flying lighted blades / frame
Old 05-11-2007 | 12:30 AM
StrykerIncognito's Avatar
StrykerIncognito
Default RE: Night flying lighted blades / frame
Heh.. I've received my new Venom Night Blades... Here we go:
(Keeping in mind I fly an Axe CP)
1. They're pretty nice. They're actually just the same length as the Axe Stock blades. They're a little smaller in width from leading to trailing edge.
2. They're thicker at the mounting hole than the stock Axe blades. You'll need to sand off about a millimeter total.
3. They're deeper from the post inward, and you'll need to trim down at least a milimeter of CF to clear the blade grips smoothly.
4. If you're going to order these blades, you'll need the Blades, the power link pins, and the seperate charger.
...and with some patience, sandpaper, and a good blade balancer, you get this: (See attached)
I'll be ording the EL wire soon.
ID:	681959   Click image for larger version
ID:	681960   Click image for larger version
ID:	681961   Click image for larger version
ID:	681962   Click image for larger version
ID:	681963   Click image for larger version
ID:	681964   Click image for larger version
