RCU Forums - View Single Post - how much shim to change down thrust?
Old 05-11-2007 | 02:13 PM
Ernie Misner's Avatar
Ernie Misner
Default RE: how much shim to change down thrust?
Hi Rob, keep us posted. From being at the field with Rob, his problem seems to be that when rolling inverted, it is taking a lot of elevator to hold it inverted, although the balance is already moved way back from the recommended point. So...... to add a bit of downthrust as an experiment, or to keep pushing the balance further and further back???
Ernie
