RCU Forums - View Single Post - Protech Tojeiro-90 build. The last one?
Old 05-11-2007 | 04:03 PM
  #172
wagen017
Default RE: Protech Tojeiro-90 build. The last one?
Today I picked up a carbon landing gear. I also decided for now to go without wheelpants. I damaged in an early attempt to go flying on a wet field with long grass also the Tru-turn spinner, so that has been off already for a while!
Main reason for changing gear was weight, and the fact that with the current gear and a 14 inch prop there is basicly NO ground clearance. Also the plane doesn't rotate when taking off, since it simply sits too low.
Weight saving: 150 grams.
Total weight now: 4040 grams.
I will let you guys know if this actually gives better flight performance.
Here two pictures:
ID:	682341   Click image for larger version
