RE: Helicopter glossary of terms
someone was saying that the number on the brushless is how many times it is rated to spin for every volt it has. IE 4100kv spins 4100rpm for every volt you give it, so if you were running a 3s lipo on it then it would run about 45510 rpm with nominal voltage and no load =)
good call on the motor size =)
