RE: BRIO Electric 10-size
no fixing points just cut a small hole in the covering so the glue gets a good bond with the balsa, i glued mine to just the covering to start with and they pulled the covering away from the balsa so i cut the small holes and glued directly to the stab and that solved that, at the fuselage i did drill a hole the size of the carbon and inserted them slightly into the fuse for more support.
kc
