RE: Gasser Maintenance
Definitely; Grab the prop and pull the engine around to check for loose bolts the first few flights. the blind nuts will stretch and seat to the firewall during the first flights. Servo screws will vibrate out. Hinges will come loose, prop needs to be re-tightened etc. Learn to check every thing. Or you will learn to check everything.
