RCU Forums - View Single Post - Air/Fuel Mix as a function of air temp
Old 02-26-2003 | 08:09 AM
strato911
Default Air/Fuel Mix as a function of air temp
Also, the higher the nitro content, the "touchier" the needle valve setting will be. If tuned using 5% nitro it may be fine for 20° of temperature fluctuations, while 20% nitro needs retuning with only 10° change.
*(hypothetical temperatures - individual results may vary).
