Air/Fuel Mix as a function of air temp
Morning paul_c,yes that is normal,I pinch the fuel line,if the engine doesn't speed up 300/400 rpm then I reset the needle valve so it does,then I point the plane vertical if the engine holds rpm without leaning then away we go, Sometimes I've changed a couple times a day,other times nothing changes for couple of months.
