RCU Forums - View Single Post - Air/Fuel Mix as a function of air temp
Old 02-26-2003 | 04:20 PM
Kaos Rulz
Default Air/Fuel Mix as a function of air temp
Paul,
Your engine is probably still in the breaking-in stage and it's not uncommon to have to re-adjust needle setting more than if it were well broken-in. I would still recommend looking for anything that might have worked loose. This is especially true with new engines.
It's also a good idea to note the position of the needle before and after flights to insure it's not moving on you.
