RCU Forums - View Single Post - Break in needle settings.. engine acting funny
Old 02-26-2003 | 11:09 PM
tylern
Default air to motor
the motor needs air and gas too.turn in the air jet all the way easy tell it stops.then turn it out 2 or more turns,start the motor and run it ,have a friend or some one help you do this.they need to give it gas and you need to turn in the air jet slow and easy.it must be about 1 3/4 to 2 turns.no less then 11/2 the motor will run faster then but you need to see and feel oil in the air from the back of motor.then run the ----- out of it and have fun!!later
and when you are done shut off gas or run it out and put oil in the carb to keep it good and will not rust ok
