RCU Forums - View Single Post - Tight diffs?
Thread: Tight diffs?
Old 05-13-2007 | 09:15 AM
AllAboutFunHobbies's Avatar
AllAboutFunHobbies
Default RE: Tight diffs?
You don't want to do that, yoru going to cause your self some trouble in the long run if one those axles bends and locks up that side yoru going to blow your whole drive train, seen it happen on a buddies GS Storm(same buggy as Hurricane), bent an axle locked up the wheel and transfered the power through the whole rear end and blew the diff and snapped the opposite side drive axle, twisted the rear center axle, stripped the spur gear, blew the center diff and broke the clutch bell. It's cool but it's not worth it.
