RCU Forums - View Single Post - need some advice
Old 05-13-2007 | 10:20 AM
Sean Bowf's Avatar
Sean Bowf
Default RE: need some advice
If the boat has good throttle response on land, it is probably too lean.
Warning: Do not rev up the motor out of the water. This could destroy the motor. Only do little "blips" to see what the throttle response is like.
I have no idea what motor is good for the boat. So if it is over propped, you might get the same results as running too lean...
Sean
