RCU Forums - View Single Post - need some advice
Old 05-13-2007 | 01:27 PM
Drmeff's Avatar
Drmeff
Default RE: need some advice
Are you SURE that is a 230? If that is a 70 inch boat, and that prop looks like it is pretty scale with the hull, I would guess it is atleast a 270, if not a 280. Also, if you are running 1/4 inch flex cable and stub, the 230 wouldn't even fit because it is a 3/16" prop.
Like gooy said though, sharpen and balance the prop, and get a tuned pipe and it will move much better!
Another thing I noticed (need another opinion on this) I wouldnt think that you should need to have that bend on the outside corners of your turn fins because I think that will be more drag than it is worth.
