RE: Question about fuel system
if its surging at high speed its possible you have a tiny leak & it will only show up at high power setting ie; when the engine is drawing max fuel. the fuel line itself can be less than tight on the inlet nipple causing air draw. also check your fuel tank setup. vibration getting to a tank could cause the same reaction esp. at high speed.
