ORIGINAL: btamxx
Hi all.
I am having a small problem with flying the Blade CP Heli in that I can start the sim and start flying the heli and under full collective it flies off the ground at an approximate rate of what looks to be about 15' per second. Another time I fly it rises less dramatically at a rate of about 3-5 feet per second. I can turn on the Headsup and measure that exactly but it is the discrepancy between flights that I'm concerned about. Has anybody had this or a similar experience?
Tnx,
Bill
Bill -- Try adjusting the "throttle trim" by rotating the knob on the TacCon controller. I think this will fix the problem. Let me know if this works for you.
