Best Servos for Combat Planes
Thanks for the info guys. What would you use for 2610 class to mount in the wing for ailerons (one for each control surface). Can I go with something smaller (i.e less weight) since I will use one on each aileron? Or would you just go twith the HS-81's or TS-35's? Thanks!
