RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 05-14-2007 | 08:33 AM
  #1300
RysiuM's Avatar
RysiuM
Default RE: gas fuel with glo plug no ignition
ORIGINAL: ROOSTERLEW
Have you considered/tried adding a pot in system and varing driver at idle?
This is exactly the setup I have. Steel wire attached to the engine cylinder = pot. The clamp on the wire (not shown on the picture) is the slider. I can regulate the current on the glow plug from 1.9A to 3.2A (for the engine startup). However it needs about 3A to start. After that I can drop the current because burning gasoline adds the heat to the glow plug. I will know much more when I tune up the engine, so I can vary the temperature and see how does it affect the performance.
