RE: Eureka Aircraft Troublemaker Build Thread
Got both gear wells done and joined the wing halves. Now I have to wait for the glue to set. I chose to use Gorilla Glue (Elmer's Ultimate Glue, same stuff) to join the wing halves. This may not be that standard, but I've had excellent luck with this stuff. As it dries, it expands into every gap and crevice. It's totally sandable and I have used it extensively on 40% airplanes. I will however, use epoxy to glass the center wing.
Going to go back to working on the fuselage. Going to work on the tank mount and servo tray mount. Maybe make a push rod for the elevators.
